Saltar al contenido principal
Vtech InnoTab 3S Rear Panel Replacement
Qué necesitas
  1. Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: paso 1, imagen 1 de 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: paso 1, imagen 2 de 3 Vtech InnoTab 3S Rear Panel Replacement, Rear Panel: paso 1, imagen 3 de 3
    • While holding the battery compartment locks down, slide the two battery doors outwards from the sides of the device.
    • Remove the batteries from the device.
  2. Vtech InnoTab 3S Rear Panel Replacement: paso 2, imagen 1 de 2 Vtech InnoTab 3S Rear Panel Replacement: paso 2, imagen 2 de 2
    • Remove six 7 mm screws from the interior of the battery compartment using a Phillips #1 screwdriver.
  3. Vtech InnoTab 3S Rear Panel Replacement: paso 3, imagen 1 de 3 Vtech InnoTab 3S Rear Panel Replacement: paso 3, imagen 2 de 3 Vtech InnoTab 3S Rear Panel Replacement: paso 3, imagen 3 de 3
    • Using a nylon spudger, remove the five caps that hide the screws.
    • Potential for device damage: Be careful not to scrape the plastic from the device using the spudger.
    • When removing the caps, hold the spudger vertical to the board to make removal easier. Also try to push in with your spudger pointing towards the bottom of the device.
    • Remove the five 5 mm Phillips #1 screws from the rear panel of the device.
  4. Vtech InnoTab 3S Rear Panel Replacement: paso 4, imagen 1 de 1
    • Carefully remove the rear panel from the front panel of the device.
    • Once the rear panel is removed, you'll be able to see the motherboard and other components within the Vtech InnoTab 3s.
Conclusión
Karina Garcia
Miembro Desde 08/30/15
830 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 8-2, Eyestone Fall 2015 Miembro de USF Tampa, Team 8-2, Eyestone Fall 2015
USFT-EYESTONE-F15S8G2
4 Miembros
9 Guías creadas
Un comentario
too dumb i tryed 7 times it didnt work i reat this 1000000-/10
Kyron Ostrander - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 628
