Saltar al contenido principal
Vtech InnoTab 3 Rear Panel Diassembly
Qué necesitas
  1. Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: paso 1, imagen 1 de 3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: paso 1, imagen 2 de 3 Vtech InnoTab 3 Rear Panel Diassembly, Rear Panel: paso 1, imagen 3 de 3
    • Slide the battery compartment door lock down.
    • While still holding the battery compartment lock down, slide the two battery doors outwards on either side of the device.
    • Carefully remove the batteries from the battery compartment.
    • The standard option for the InnoTab 3 is four AA batteries. Vtech also offers a rechargeable battery online, but both battery options are removed from the device the same way.
  2. Vtech InnoTab 3 Rear Panel Diassembly: paso 2, imagen 1 de 1
    • Remove the six 7.6mm screws found in the battery compartment using a PH00 screwdriver.
  3. Vtech InnoTab 3 Rear Panel Diassembly: paso 3, imagen 1 de 3 Vtech InnoTab 3 Rear Panel Diassembly: paso 3, imagen 2 de 3 Vtech InnoTab 3 Rear Panel Diassembly: paso 3, imagen 3 de 3
    • There are three hidden screws on the back of the device, two at the top and one near the bottom.
    • Using a nylon or metal spudger, remove the three caps that hide the screws.
    • Remove the 5mm screw near the bottom and the two 7.6mm at the top using a PH00 screwdriver.
  4. Vtech InnoTab 3 Rear Panel Diassembly: paso 4, imagen 1 de 1
    • Carefully separate the back panel from the front panel revealing the motherboard connected to the front panel.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 1,188
