Introducción
In this guide, we will be showing you how to remove and replace the Memory Modules.
Partes
No se requieren partes.
  1. Slide the battery lock latches into the unlocked position.
    • Slide the battery lock latches into the unlocked position.
  2. Slide the battery toward the back of the computer to remove.
    • Slide the battery toward the back of the computer to remove.
  3. Remove the eight screws from the access panel.
    • Remove the eight screws from the access panel.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    • Lift the edge of the access panel that is closest to the center of the computer.
  5. Remove the access panel.
    • Remove the access panel.
  6. If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
    • If applicable, remove the top memory module by using your fingertips to carefully spread apart the securing clips on each end of the top memory module connector until the memory module pops up.
  7. Slide the memory module out of the socket.
    • Slide the memory module out of the socket.
  8. If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
    • If applicable, remove the bottom memory module by using your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  9. Slide the memory module out of the socket.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,735 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 14
