Saltar al contenido principal
Introducción
In this guide, we will be showing you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. Slide the battery lock latches into the unlocked position.
    • Slide the battery lock latches into the unlocked position.
  2. Slide the battery toward the back of the computer to remove.
    • Slide the battery toward the back of the computer to remove.
  3. Remove the screw that secures the hard drive access panel to the base of the computer.
    • Remove the screw that secures the hard drive access panel to the base of the computer.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Insert a plastic scribe into the slot and lift up the access panel, then remove the panel from the computer.
    • Insert a plastic scribe into the slot and lift up the access panel, then remove the panel from the computer.
  6. Remove the two screws that secure the hard drive in place.
    • Remove the two screws that secure the hard drive in place.
  7. Slide the hard drive toward the right side of the computer.
    • Slide the hard drive toward the right side of the computer.
  8. Lift the hard drive from the computer.
    • Lift the hard drive from the computer.
Linea de Meta
Johnathan Hammond
Miembro Desde 28/02/18
35,861 Reputación
408 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 37
