Saltar al contenido principal
Vornado 133 Compact Air Circulator Fuse Replacement
Qué necesitas
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: paso 1, imagen 1 de 1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: paso 2, imagen 1 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: paso 2, imagen 2 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: paso 2, imagen 3 de 3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: paso 3, imagen 1 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: paso 3, imagen 2 de 3 Vornado 133 Compact Air Circulator Fuse Replacement: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
Conclusión
Follow these instructions in reverse order to install the new fuse and close the access panel.
11 personas más completaron esta guía.
Erin Klein
Miembro Desde 07/06/17
483 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team S1-G2, Liner Summer 2017 Miembro de UW Tacoma, Team S1-G2, Liner Summer 2017
UWT-LINER-SU17S1G2
4 Miembros
4 Guías creadas
10 comentarios
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - Contestar
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - Contestar
Fast-acting or slow-acting?
James Olsen - Contestar
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - Contestar
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 90
Ultimos 30 días: 311
Todo El Tiempo: 32,757
