Introducción
This can give you more insight on how this device was assembled as I didn't find any advice on VFD 710 or Vodafone V8 made by ZTE.
  1. To open the device you need do apply pressure at the bottom and up to get rid of the glued mini covers.
    • To open the device you need do apply pressure at the bottom and up to get rid of the glued mini covers.
  2. Put the back cover gently away - remove the finger sensor cable gently from the motherboard. Also put away gently battery and digitizer gently pull the cables from the glue as well the battery is well glued (you might demage it-very tight).
    • Put the back cover gently away - remove the finger sensor cable gently from the motherboard. Also put away gently battery and digitizer gently pull the cables from the glue as well the battery is well glued (you might demage it-very tight).
    • this was a complete teardown of the device - you can replace virtually anything.
Conclusión
brejzek
Miembro Desde 11/09/18
97 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 4
Todo El Tiempo: 20
