Introducción
Hello! This guide will help you replace the Wi-Fi antenna in your Vizio VTAB1008.
Qué necesitas
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Using the blue spudger/prying tool remove antenna connectors by prying them up from the motherboard.
Casi Terminas!
Conclusión
