Introducción
Hello! This is a guide on how to replace the front-facing camera and light sensor in your Vizio VTAB1008.
Qué necesitas
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Remove the screw with the J1 screwdriver or screw bit.
Casi Terminas!
Conclusión
