Introducción
Hello! This guide will show you how to replace the digitizer on your Vizio VTAB1008.
Qué necesitas
Carefully slide the heavy duty opening tool between the gap on the side of the device with no buttons.
Corner tabs may require a more forceful prying tool. If needed, carefully insert the metal prying tool into corners to separate the tabs.
Casi Terminas!
Conclusión
