Saltar al contenido principal
Vizio SmartCast Tablet Remote XR6P Back Cover Replacement
Qué necesitas
  1. Vizio SmartCast Tablet Remote XR6P Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
  2. Vizio SmartCast Tablet Remote XR6P Back Cover Replacement: paso 2, imagen 1 de 1
    • Gently pry up on the plate with the spudger. You may hear some cracking noises as you work the spudger around your device, this is normal.
  3. Vizio SmartCast Tablet Remote XR6P Back Cover Replacement: paso 3, imagen 1 de 1
    • Pry around the edges of the tablet with your fingers until you have successfully removed the back of the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 323
