Saltar al contenido principal
Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement
Qué necesitas
  1. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement, Micro-USB Port: paso 1, imagen 1 de 1
  2. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 2, imagen 1 de 2 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 2, imagen 2 de 2
    • Insert the tip of the nylon spudger under the black flap, and pull upwards toward yourself to disconnect it.
    • Be careful, as the flap can easily break off.
  3. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 3, imagen 1 de 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 3, imagen 2 de 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 3, imagen 3 de 3
    • Using the T-5 bit, unscrew the three 5mm screws, two attached to the green board, one attached to the black board.
  4. Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 4, imagen 1 de 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 4, imagen 2 de 3 Vizio SmartCast Tablet Remote XR6M Micro-USB Port Replacement: paso 4, imagen 3 de 3
    • Using the nylon spudger, remove the silver cylindrical component followed by the green then black components
    • Be careful not to break the wires that are holding the three components together.
Conclusión
tate campbell
Miembro Desde 09/17/18
439 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 352
