Saltar al contenido principal
Vizio CT15 Keyboard Replacement
Qué necesitas
  1. Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: paso 1, imagen 1 de 2 Vizio CT15 Keyboard Replacement, Vizio CT15 Back Panel Removal: paso 1, imagen 2 de 2
    • Turn the laptop off and remove all power cables.
    • Remove the six Phillips #0 screws.
    • Pull the back cover off.
  2. Vizio CT15 Keyboard Replacement, Battery: paso 2, imagen 1 de 1
  3. Vizio CT15 Keyboard Replacement: paso 3, imagen 1 de 2 Vizio CT15 Keyboard Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool or your fingers to pry the battery up and pull it from the laptop.
  4. Vizio CT15 Keyboard Replacement, Speakers: paso 4, imagen 1 de 2 Vizio CT15 Keyboard Replacement, Speakers: paso 4, imagen 2 de 2
    • Unplug the wire connecting the speakers to the motherboard.
  5. Vizio CT15 Keyboard Replacement: paso 5, imagen 1 de 2 Vizio CT15 Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the four Phillips #0 screws.
    • Pull the speakers out to remove.
  6. Vizio CT15 Keyboard Replacement: paso 6, imagen 1 de 3 Vizio CT15 Keyboard Replacement: paso 6, imagen 2 de 3 Vizio CT15 Keyboard Replacement: paso 6, imagen 3 de 3
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the ribbon cables out of the ZIF connector.
    • These wires are not connected to the speakers. We are only unplugging them to remove the wire underneath.
  7. Vizio CT15 Keyboard Replacement: paso 7, imagen 1 de 2 Vizio CT15 Keyboard Replacement: paso 7, imagen 2 de 2
    • Pull off the black strips of tape from the speaker wires and remove the speakers from the laptop.
  8. Vizio CT15 Keyboard Replacement, CPU Fan: paso 8, imagen 1 de 2 Vizio CT15 Keyboard Replacement, CPU Fan: paso 8, imagen 2 de 2
    • Unplug the fan from the motherboard.
  9. Vizio CT15 Keyboard Replacement: paso 9, imagen 1 de 2 Vizio CT15 Keyboard Replacement: paso 9, imagen 2 de 2
    • Remove the three Phillips #0 screws.
    • Pull the fan out to remove.
  10. Vizio CT15 Keyboard Replacement, Keyboard: paso 10, imagen 1 de 2 Vizio CT15 Keyboard Replacement, Keyboard: paso 10, imagen 2 de 2
    • Remove the four Philips #0 screws from the heatsink.
    • Pull up and out to remove the heatsink from the laptop.
  11. Vizio CT15 Keyboard Replacement: paso 11, imagen 1 de 2 Vizio CT15 Keyboard Replacement: paso 11, imagen 2 de 2
    • Remove the eight Phillips #0 screws from the motherboard.
    • Lift the motherboard up and out to remove it from the laptop.
  12. Vizio CT15 Keyboard Replacement: paso 12, imagen 1 de 1
    • Remove the four Phillips #00 screws that hold the keyboard to the laptop case.
  13. Vizio CT15 Keyboard Replacement: paso 13, imagen 1 de 3 Vizio CT15 Keyboard Replacement: paso 13, imagen 2 de 3 Vizio CT15 Keyboard Replacement: paso 13, imagen 3 de 3
    • Use a metal spudger to carefully push the keyboard out of place.
    • Carefully flip the laptop over and pull the keyboard out.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 866
