Saltar al contenido principal
Vivotek FD8169 Motherboard Replacement
Qué necesitas
  1. Vivotek FD8169 Motherboard Replacement, Dome Cover: paso 1, imagen 1 de 1
    • Loosen the outside screw.
  2. Vivotek FD8169 Motherboard Replacement: paso 2, imagen 1 de 1
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Motherboard Replacement, Camera Module: paso 3, imagen 1 de 1
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Motherboard Replacement: paso 4, imagen 1 de 1
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Motherboard Replacement: paso 5, imagen 1 de 1
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Motherboard Replacement: paso 6, imagen 1 de 1
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Motherboard Replacement: paso 7, imagen 1 de 1
    • Pull the camera out from the camera base.
  8. Vivotek FD8169 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
  9. Vivotek FD8169 Motherboard Replacement: paso 9, imagen 1 de 1
    • Once the screws are gone, lift the faulty motherboard and replace with a new one.
Conclusión
Artem Dudko
Miembro Desde 10/18/21
135 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-6, Simcock Fall 2021 Miembro de UMass Dartmouth, Team 1-6, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G6
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 243
