Saltar al contenido principal
Vivitar Vivicam T027 Screen Replacement
Qué necesitas
  1. Vivitar Vivicam T027 Screen Replacement, Screen: paso 1, imagen 1 de 2 Vivitar Vivicam T027 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: paso 2, imagen 1 de 1
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: paso 3, imagen 1 de 2 Vivitar Vivicam T027 Screen Replacement: paso 3, imagen 2 de 2
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: paso 6, imagen 1 de 1
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: paso 7, imagen 1 de 2 Vivitar Vivicam T027 Screen Replacement: paso 7, imagen 2 de 2
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Conclusión
Una persona más ha completado esta guía.
Nicole Knoebel
Miembro Desde 03/11/15
258 Reputación
2 Guías creadas
Equipo
Marist, Team 15-13, Laflen Spring 2015 Miembro de Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Miembros
3 Guías creadas
2 comentarios
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Contestar
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 793
