Saltar al contenido principal
Vivitar Vivicam T027 Power Button Replacement
Qué necesitas
  1. Vivitar Vivicam T027 Power Button Replacement, Power Button: paso 1, imagen 1 de 2 Vivitar Vivicam T027 Power Button Replacement, Power Button: paso 1, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
    • You will find one screw on the top, one on the bottom, and one on each side of the camera.
    • Put the screws in a safe place so you can find them and put them back in later.
  2. Vivitar Vivicam T027 Power Button Replacement: paso 2, imagen 1 de 1
    • Remove the sticker on the top of the camera.
    • Use the Phillips #00 screwdriver to remove the screw that was underneath the sticker.
  3. Vivitar Vivicam T027 Power Button Replacement: paso 3, imagen 1 de 2 Vivitar Vivicam T027 Power Button Replacement: paso 3, imagen 2 de 2
    • Separate the front and the back of the camera completely to expose the motherboard.
  4. Vivitar Vivicam T027 Power Button Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Locate the power button on the top of the camera.
    • Using tweezers, gently remove the black plastic cover from the power button.
  5. Vivitar Vivicam T027 Power Button Replacement: paso 5, imagen 1 de 2 Vivitar Vivicam T027 Power Button Replacement: paso 5, imagen 2 de 2
    • Using a soldering kit, de-solder the black and red wire from the silver power button.
    • Solder the new power button to the black and red wire.
    • To avoid burns, be careful of the heat from the soldering iron.
    • Reference the soldering guide for assistance!
Conclusión
Dana
Miembro Desde 03/11/15
110 Reputación
1 Guía escrita
Equipo
Marist, Team 15-13, Laflen Spring 2015 Miembro de Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 914
