Introducción
If the power button on your Vivitar Vivicam T027 digital camera breaks or gets jammed, you may need to replace it. This guide will show you how.
Note: This repair requires soldering. View the soldering guide for more information.
Qué necesitas
Using a Phillips #00 screwdriver, remove four exposed 3mm screws.
You will find one screw on the top, one on the bottom, and one on each side of the camera.
Casi Terminas!
Conclusión
