Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide provides instructions for removal of the glass lens cover on the front of the camcorder's water proof case. There are small screws and a glass part in this repair, so have a clean work space and keep the case on a flat surface to avoid losing screws or dropping the glass lens cover.
Partes
No se especificaron partes.
  1. Place waterproof case on flat surface, with the lens cover facing up.
    • Place waterproof case on flat surface, with the lens cover facing up.
  2. Remove the six 4.5mm Phillips #00 screws from the black lens cover trim. Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
    • Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
  3. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  4. While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface. While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
    • While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
  5. Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case. Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
    • Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
  6. There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly. There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
    • There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
Conclusión
Una persona más ha completado esta guía.
Jordan Baum
Miembro Desde 13/02/16
348 Reputación
2 Guías creadas
Equipo
IUPUI, Team 54-6, Wilson Spring 2016 Miembro de IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Miembros
5 Guías creadas
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
Andrew Hinsley - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 963
