Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This guide provides the instructions needed to remove the motherboard from the 781HD DVR camcorder.
Partes
No se especificaron partes.
  1. Begin with the camcorder lens up on a clear working surface. Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side. Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  4. Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard. The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery. The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
  5. Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case. Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
    • Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
  6. Gently lift the motherboard, handling it by the edges.
    • Gently lift the motherboard, handling it by the edges.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 54-6, Wilson Spring 2016 Miembro de IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Miembros
5 Guías creadas
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
Heki Kahni - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 1,085
