Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Partes
No se especificaron partes.
  1. Begin with the camcorder lens up on a clear working surface. Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side. Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  3. Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  4. Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard. The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery. The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
Conclusión
Jordan Baum
Miembro Desde 13/02/16
348 Reputación
2 Guías creadas
Equipo
IUPUI, Team 54-6, Wilson Spring 2016 Miembro de IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
3 Miembros
5 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 190
