Introducción
This guide will show you how to replace the LCD display if the screen breaks. Soldering and de-soldering will be necessary.
Qué necesitas
Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
Remove the three 4.0mm screws holding down the circuit board with the Phillips #00 screwdriver.
Desolder the black wire from the LCD.
For soldering information, see our guide: Cómo soldar y desoldar conexiones.
Una persona más ha completado esta guía.
