Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
This guide will show you the steps to replacing the battery. Soldering and de-soldering will be necessary.
  1. Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Pry a thin tool under the battery.
    • Pry a thin tool under the battery.
    • Be gentle and try not to bend the battery.
    • Slide the tool around all sides of the battery. Separate it evenly on all sides for the best result.
  5. Soldering guns are hot and can easily damage the device. Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
    • Soldering guns are hot and can easily damage the device.
    • Desolder the two connections between the red and blue wires where the battery connects to the circuit board.Soldering guns are hot and can easily damage the device.
    • For soldering information, see our guide: Cómo soldar y desoldar conexiones.
    • If you are removing the LCD display this step is unnecessary.
Conclusión
3 personas más completaron esta guía.
Max Hudson
Miembro Desde 14/10/14
422 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-41, Amido Fall 2014 Miembro de Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
4 Miembros
12 Guías creadas
My tablet shows the icon battery What that mean
paularslay - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 5,887
