Saltar al contenido principal
Visual Land Prestige Elite 9Q Battery Replacement
Qué necesitas
  1. Visual Land Prestige Elite 9Q Battery  Replacement, Battery: paso 1, imagen 1 de 1
    • Using the large plastic opening tool, start along a side of the device and apply light pressure in the seam between the top and bottom outer covers.
    • Maneuver the smaller plastic opening tool at the spot of the large opening tool and slowly slide along the edge.
    • You should feel each plastic connection begin to loosen.
  2. Visual Land Prestige Elite 9Q Battery  Replacement: paso 2, imagen 1 de 1
    • Move tool around each connection, and continue around the device until all connections have been loosened.
    • The user risks damaging the connections if tool is slid to fast.
  3. Visual Land Prestige Elite 9Q Battery  Replacement: paso 3, imagen 1 de 2 Visual Land Prestige Elite 9Q Battery  Replacement: paso 3, imagen 2 de 2
    • Once all connections have been loosened and using a soft surface, place the device onto its screen, and lift gently on the outer casing.
    • Open the casing and lay as shown keeping the speaker wires loose.
  4. Visual Land Prestige Elite 9Q Battery  Replacement: paso 4, imagen 1 de 2 Visual Land Prestige Elite 9Q Battery  Replacement: paso 4, imagen 2 de 2
    • Use wide tip tweezers to gently remove the three pieces of tape attached to battery.
    • Once the tape has been removed, the battery will be free from the tablet except for the wired connections to the circuit board.
    • Be careful not to severely damage the tape as this is what will hold the battery in place.
    • Mark where the positive (red) and negative (black) wires are on the circuit board.
    • Markings will be used for reassembly.
  5. Visual Land Prestige Elite 9Q Battery  Replacement: paso 5, imagen 1 de 2 Visual Land Prestige Elite 9Q Battery  Replacement: paso 5, imagen 2 de 2
    • Before disconnecting battery, review Soldering Tips to ensure proper soldering.
    • Use soldering iron to remove +(red) battery lead.
    • Touch the positive wire to a metal surface acting as a ground to discharge the battery. Depending on the charge level of the battery, it may take up to 30 seconds to insure that it is fully discharged.
    • 'Ensure that the wires and solder do not touch each other, for this will damage the device
    • Remove the -(black) battery lead.
    • Remove and discard the old battery. Insert new battery and solder the positive and then the negative terminals to the circuit board.
Conclusión
2 personas más completaron esta guía.
LAWRENCE SMITH
Miembro Desde 07/19/16
108 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 2,248
