Saltar al contenido principal
Visual Land Prestige Elite 7Q Speaker Replacement
Qué necesitas
  1. Visual Land Prestige Elite 7Q Speaker Replacement, Speaker: paso 1, imagen 1 de 2 Visual Land Prestige Elite 7Q Speaker Replacement, Speaker: paso 1, imagen 2 de 2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Speaker Replacement: paso 2, imagen 1 de 2 Visual Land Prestige Elite 7Q Speaker Replacement: paso 2, imagen 2 de 2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Speaker Replacement: paso 3, imagen 1 de 3 Visual Land Prestige Elite 7Q Speaker Replacement: paso 3, imagen 2 de 3 Visual Land Prestige Elite 7Q Speaker Replacement: paso 3, imagen 3 de 3
    • Soldering iron may be dangerous for inexperienced users. For additional information on how to use a soldering iron, click here.
    • Use a soldering iron to detach the speaker wires from the motherboard.
  4. Visual Land Prestige Elite 7Q Speaker Replacement: paso 4, imagen 1 de 3 Visual Land Prestige Elite 7Q Speaker Replacement: paso 4, imagen 2 de 3 Visual Land Prestige Elite 7Q Speaker Replacement: paso 4, imagen 3 de 3
    • Use a curved metal spudger to remove the speaker from the back case.
    • The speaker is held in place by an adhesive and can be difficult to remove.
Conclusión
Equipo
UC Davis, Team 2-1, Oliver Fall 2016 Miembro de UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 153
