Saltar al contenido principal
Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement
Qué necesitas
  1. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: paso 1, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement, Digitizer / Front Screen: paso 1, imagen 2 de 2
    • At the bottom of the tablet, remove the two 3.6mm screws with a Phillips #000 screwdriver.
  2. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 2, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 2, imagen 2 de 2
    • Wedge a plastic opening tool into the edges of the tablet to pry it open.
  3. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 3, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 3, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 3, imagen 3 de 3
    • Wedge a curved metal spudger under the speaker in order to remove it.
    • The speaker is held in place by an adhesive and can be difficult to remove.
  4. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 4, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 4, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove the two 3.6mm screws.
  5. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 5, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 5, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to lift the black tab.
  6. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 6, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 6, imagen 2 de 2
    • Carefully lift and remove the ribbon cable from the black tab.
  7. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 7, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 7, imagen 2 de 2
    • Use a plastic opening tool to remove the camera.
  8. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 8, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 8, imagen 2 de 2
    • Use a Phillips #000 screwdriver to remove the 3.6mm screw.
  9. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 9, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 9, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 9, imagen 3 de 3
    • Lift the tape holding down the battery.
  10. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 10, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 10, imagen 2 de 2
    • Wedge a plastic card underneath the battery to remove it.
  11. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 11, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 11, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 11, imagen 3 de 3
  12. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 12, imagen 1 de 2 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 12, imagen 2 de 2
  13. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 13, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 13, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 13, imagen 3 de 3
  14. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 14, imagen 1 de 1
    • Safely remove the battery and motherboard from the tablet.
  15. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 15, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 15, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 15, imagen 3 de 3
    • Lift the tape on the sides.
  16. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 16, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 16, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 16, imagen 3 de 3
    • Use a Phillips #000 screwdriver to remove the three 2.5mm screws.
  17. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 17, imagen 1 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 17, imagen 2 de 3 Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 17, imagen 3 de 3
    • Wedge a metal spudger underneath the LCD screen to remove it.
  18. Visual Land Prestige Elite 7Q Digitizer / Front Screen Replacement: paso 18, imagen 1 de 1
    • Replace the front screen to replace the digitizer.
Conclusión
Equipo
UC Davis, Team 2-1, Oliver Fall 2016 Miembro de UC Davis, Team 2-1, Oliver Fall 2016
UCD-OLIVER-F16S2G1
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 504
