Saltar al contenido principal
Visual Land Prestige 7L Front Facing Camera Replacement
Qué necesitas
  1. Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 2 Visual Land Prestige 7L Front Facing Camera Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Front Facing Camera Replacement: paso 2, imagen 1 de 3 Visual Land Prestige 7L Front Facing Camera Replacement: paso 2, imagen 2 de 3 Visual Land Prestige 7L Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Front Facing Camera Replacement: paso 3, imagen 1 de 3 Visual Land Prestige 7L Front Facing Camera Replacement: paso 3, imagen 2 de 3 Visual Land Prestige 7L Front Facing Camera Replacement: paso 3, imagen 3 de 3
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
  4. Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: paso 4, imagen 1 de 2 Visual Land Prestige 7L Front Facing Camera Replacement, Front Facing Camera: paso 4, imagen 2 de 2
    • Remove the adhesive padding.
  5. Visual Land Prestige 7L Front Facing Camera Replacement: paso 5, imagen 1 de 2 Visual Land Prestige 7L Front Facing Camera Replacement: paso 5, imagen 2 de 2
    • Unclip the connector that attaches the camera to the motherboard.
    • For more information on unclipping connectors see this How To Guide
    • Do not pull on the camera until you're sure that it's unclipped, the gold connection will rip.
    • Gently pop the camera out of the connector and off the case.
Conclusión
Una persona más ha completado esta guía.
Greg Azzalina
Miembro Desde 01/28/15
263 Reputación
1 Guía escrita
Equipo
Penn State, Team 2-25, Kaschak Winter 2015 Miembro de Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 273
