Saltar al contenido principal
  1. Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from. All screws throughout this guide are the same 3mm size. All screws throughout this guide are the same 3mm size.
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Using the spudger, create a small opening to be used to open the back case. While holding the case open, insert the plastic opening tool to get a larger opening. Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. now that the case is open, carefully remove the speakers and set aside. now that the case is open, carefully remove the speakers and set aside. now that the case is open, carefully remove the speakers and set aside.
    • now that the case is open, carefully remove the speakers and set aside.
  4. Gently remove the speakers from the back case with tweezers and set the case aside. Gently remove the speakers from the back case with tweezers and set the case aside.
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Remove yellow tape from surrounding components. Remove yellow tape from surrounding components. Remove yellow tape from surrounding components.
    • Remove yellow tape from surrounding components.
  6. Kits de reparación de iPhone X
    ¿Garantía vencida? No te preocupes, tenemos la solución.
    Comprar Ahora
    Comprar Ahora
  7. insert the spudger and gently work around and underneath the battery. With the battery separated from the LCD Display, set it aside. The battery is held down by very strong adhesive.
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  8. Desolder and remove the 2 wires from the motherboard.
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  9. Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click. Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible. Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  10. Locate the LCD Connector. Using tweezers, grip the small black tab connected to the white plastic. Gently lift the tab towards you until it clicks.
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  11. Locate the Touchscreen connector and grip the forward-most black tab with the tweezers. Lift the tab towards you until you feel an audible click. Gently remove the connector by pulling straight out, gripping the black connector head.
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  12. Gently lift up the WiFi antenna and set aside. Gently lift up the WiFi antenna and set aside.
    • Gently lift up the WiFi antenna and set aside.
  13. Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them. Gently lift up on the controller and leave it hanging loose.
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  14. Remove screws located on motherboard. Place on magnetic mat and label them
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
Conclusión
4 personas más completaron esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 1,109
