Saltar al contenido principal
Visual Land Prestige 10 LCD Display Replacement
Qué necesitas
  1. Visual Land Prestige 10 LCD Display Replacement, Back Case: paso 1, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement, Back Case: paso 1, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement, Back Case: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 LCD Display Replacement: paso 2, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 2, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 2, imagen 3 de 3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 LCD Display Replacement: paso 3, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 3, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 3, imagen 3 de 3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 LCD Display Replacement: paso 4, imagen 1 de 2 Visual Land Prestige 10 LCD Display Replacement: paso 4, imagen 2 de 2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 LCD Display Replacement, Front Facing Camera: paso 5, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement, Front Facing Camera: paso 5, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement, Front Facing Camera: paso 5, imagen 3 de 3
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  6. Visual Land Prestige 10 LCD Display Replacement, Battery: paso 6, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement, Battery: paso 6, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement, Battery: paso 6, imagen 3 de 3
    • Remove yellow tape from surrounding components.
  7. Visual Land Prestige 10 LCD Display Replacement: paso 7, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 7, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 7, imagen 3 de 3
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  8. Visual Land Prestige 10 LCD Display Replacement: paso 8, imagen 1 de 1
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  9. Visual Land Prestige 10 LCD Display Replacement, Motherboard: paso 9, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement, Motherboard: paso 9, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement, Motherboard: paso 9, imagen 3 de 3
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  10. Visual Land Prestige 10 LCD Display Replacement: paso 10, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 10, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement: paso 10, imagen 3 de 3
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  11. Visual Land Prestige 10 LCD Display Replacement: paso 11, imagen 1 de 2 Visual Land Prestige 10 LCD Display Replacement: paso 11, imagen 2 de 2
    • Gently lift up the WiFi antenna and set aside.
  12. Visual Land Prestige 10 LCD Display Replacement: paso 12, imagen 1 de 2 Visual Land Prestige 10 LCD Display Replacement: paso 12, imagen 2 de 2
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  13. Visual Land Prestige 10 LCD Display Replacement: paso 13, imagen 1 de 2 Visual Land Prestige 10 LCD Display Replacement: paso 13, imagen 2 de 2
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
  14. Visual Land Prestige 10 LCD Display Replacement, LCD Display: paso 14, imagen 1 de 3 Visual Land Prestige 10 LCD Display Replacement, LCD Display: paso 14, imagen 2 de 3 Visual Land Prestige 10 LCD Display Replacement, LCD Display: paso 14, imagen 3 de 3
    • Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
    • Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
    • Set aside the LCD Assembly.
    • The LCD display and backlight are separated from one another. Be sure to remember how they are aligned when putting the device back together.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,622
