Saltar al contenido principal
Visual Land Prestige 10 Front Facing Camera Replacement
Qué necesitas
  1. Visual Land Prestige 10 Front Facing Camera Replacement, Back Case: paso 1, imagen 1 de 3 Visual Land Prestige 10 Front Facing Camera Replacement, Back Case: paso 1, imagen 2 de 3 Visual Land Prestige 10 Front Facing Camera Replacement, Back Case: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Front Facing Camera Replacement: paso 2, imagen 1 de 3 Visual Land Prestige 10 Front Facing Camera Replacement: paso 2, imagen 2 de 3 Visual Land Prestige 10 Front Facing Camera Replacement: paso 2, imagen 3 de 3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Front Facing Camera Replacement: paso 3, imagen 1 de 3 Visual Land Prestige 10 Front Facing Camera Replacement: paso 3, imagen 2 de 3 Visual Land Prestige 10 Front Facing Camera Replacement: paso 3, imagen 3 de 3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Front Facing Camera Replacement: paso 4, imagen 1 de 2 Visual Land Prestige 10 Front Facing Camera Replacement: paso 4, imagen 2 de 2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 1 de 3 Visual Land Prestige 10 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 2 de 3 Visual Land Prestige 10 Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 3 de 3
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 235
