Saltar al contenido principal
  1. Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from. All screws throughout this guide are the same 3mm size. All screws throughout this guide are the same 3mm size.
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Using the spudger, create a small opening to be used to open the back case. While holding the case open, insert the plastic opening tool to get a larger opening. Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. now that the case is open, carefully remove the speakers and set aside. now that the case is open, carefully remove the speakers and set aside. now that the case is open, carefully remove the speakers and set aside.
    • now that the case is open, carefully remove the speakers and set aside.
  4. Gently remove the speakers from the back case with tweezers and set the case aside. Gently remove the speakers from the back case with tweezers and set the case aside.
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Remove yellow tape from surrounding components. Remove yellow tape from surrounding components. Remove yellow tape from surrounding components.
    • Remove yellow tape from surrounding components.
  6. insert the spudger and gently work around and underneath the battery. With the battery separated from the LCD Display, set it aside. The battery is held down by very strong adhesive.
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Baterías para ordenadores portátiles
    Un pequeño arreglo para un gran resultado.
    Comprar Ahora
    Comprar Ahora
  8. Desolder and remove the 2 wires from the motherboard.
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  9. Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click. Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible. Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  10. Locate the LCD Connector. Using tweezers, grip the small black tab connected to the white plastic. Gently lift the tab towards you until it clicks.
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  11. Locate the Touchscreen connector and grip the forward-most black tab with the tweezers. Lift the tab towards you until you feel an audible click. Gently remove the connector by pulling straight out, gripping the black connector head.
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  12. Gently lift up the WiFi antenna and set aside. Gently lift up the WiFi antenna and set aside.
    • Gently lift up the WiFi antenna and set aside.
  13. Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them. Gently lift up on the controller and leave it hanging loose.
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  14. Remove screws located on motherboard. Place on magnetic mat and label them
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
  15. Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them. Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers. Set aside the LCD Assembly.
    • Remove the screws and plastic tabs holding the LCD Display and place them on the magnetic mat. Label them.
    • Gently remove the LCD Display and backlight by lifting up the LCD Connector with your fingers.
    • Set aside the LCD Assembly.
    • The LCD display and backlight are separated from one another. Be sure to remember how they are aligned when putting the device back together.
  16. Simply lift up the loose metal frame and set aside.
    • Simply lift up the loose metal frame and set aside.
  17. Be extremely careful removing the touchscreen, avoiding sharp glass and hot surfaces. Using the heating pad, heat the edges of the touchscreen to loosen the adhesive. using the spudger, slowly and gently work around the edges, removing the touchscreen.
    • Be extremely careful removing the touchscreen, avoiding sharp glass and hot surfaces.
    • Using the heating pad, heat the edges of the touchscreen to loosen the adhesive.
    • using the spudger, slowly and gently work around the edges, removing the touchscreen.
    • The Tablet we used came with a shattered screen, making this step much more difficult.
Conclusión
4 personas más completaron esta guía.
Great write up, but have a question . Could you heat up the adhesive for the digitizer like an iPad and remove it without taking everything apart?
Michael - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 3
Últimos 30 Días: 12
Todo El Tiempo: 1,545
