Saltar al contenido principal
Visual Land Prestige 10 Battery Replacement
Qué necesitas
  1. Visual Land Prestige 10 Battery Replacement, Back Case: paso 1, imagen 1 de 3 Visual Land Prestige 10 Battery Replacement, Back Case: paso 1, imagen 2 de 3 Visual Land Prestige 10 Battery Replacement, Back Case: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Battery Replacement: paso 2, imagen 1 de 3 Visual Land Prestige 10 Battery Replacement: paso 2, imagen 2 de 3 Visual Land Prestige 10 Battery Replacement: paso 2, imagen 3 de 3
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Battery Replacement: paso 3, imagen 1 de 3 Visual Land Prestige 10 Battery Replacement: paso 3, imagen 2 de 3 Visual Land Prestige 10 Battery Replacement: paso 3, imagen 3 de 3
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Battery Replacement: paso 4, imagen 1 de 2 Visual Land Prestige 10 Battery Replacement: paso 4, imagen 2 de 2
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Battery Replacement, Battery: paso 5, imagen 1 de 3 Visual Land Prestige 10 Battery Replacement, Battery: paso 5, imagen 2 de 3 Visual Land Prestige 10 Battery Replacement, Battery: paso 5, imagen 3 de 3
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Battery Replacement: paso 6, imagen 1 de 3 Visual Land Prestige 10 Battery Replacement: paso 6, imagen 2 de 3 Visual Land Prestige 10 Battery Replacement: paso 6, imagen 3 de 3
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Battery Replacement: paso 7, imagen 1 de 1
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
Conclusión
8 personas más completaron esta guía.
7 comentarios
Wat if the charge port how do u replace it Visaul land 10.1
jessiepettway - Contestar
Thank you for posting. Great illustrations. Got mine apart so easy.
Lori Pepper - Contestar
where can I get a replacement battery for Visual Land Prestige 10D tablet?
John Conger - Contestar
Where can I get a replacement battery for Visual Land Prestige 10.1 tablet???
Thank you.
Belinda Rivera
brp52@hotmail.com
Belinda Lorenzana - Contestar
where can I get a replacement battery for visionland prestige 10 3.7v
Fred Maxwell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 8,151
