Saltar al contenido principal
Visioneer OneTouch 7400 USB Belt Replacement
Qué necesitas
  1. Visioneer OneTouch 7400 USB Belt Replacement, Outer Case: paso 1, imagen 1 de 1
    • On the bottom of the scanner, remove the screw at the top left side.
  2. Visioneer OneTouch 7400 USB Belt Replacement: paso 2, imagen 1 de 2 Visioneer OneTouch 7400 USB Belt Replacement: paso 2, imagen 2 de 2
    • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
    • Remove the screw beneath the foot-pad.
  3. Visioneer OneTouch 7400 USB Belt Replacement: paso 3, imagen 1 de 3 Visioneer OneTouch 7400 USB Belt Replacement: paso 3, imagen 2 de 3 Visioneer OneTouch 7400 USB Belt Replacement: paso 3, imagen 3 de 3
    • Rotate the scanner so the screw hole is located on the top left hand side.
    • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
    • Gently pry the two casements apart beginning above the screw hole and working your way around.
    • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
  4. Visioneer OneTouch 7400 USB Belt Replacement: paso 4, imagen 1 de 1
    • Separate the two casement pieces.
  5. Visioneer OneTouch 7400 USB Belt Replacement, Belt: paso 5, imagen 1 de 1
    • Remove the screw holding the tension spring in place.
  6. Visioneer OneTouch 7400 USB Belt Replacement: paso 6, imagen 1 de 1
    • Use the plastic opening tool to lift up the tension spring.
    • Be careful. The spring will fly.
  7. Visioneer OneTouch 7400 USB Belt Replacement: paso 7, imagen 1 de 1
    • Remove the belt from the spool.
    • The spool is a loose piece; don't lose it.
  8. Visioneer OneTouch 7400 USB Belt Replacement: paso 8, imagen 1 de 1
    • Loosen the belt enough to turn over the sensor bar.
  9. Visioneer OneTouch 7400 USB Belt Replacement: paso 9, imagen 1 de 2 Visioneer OneTouch 7400 USB Belt Replacement: paso 9, imagen 2 de 2
    • With the sensor bar turned upside down, remove the screw in the middle of the bar.
    • Lift off the metal plate if it does not come away with the screw.
  10. Visioneer OneTouch 7400 USB Belt Replacement: paso 10, imagen 1 de 1
    • Carefully lift the belt out of the groove in the sensor bar to remove.
Conclusión
Jena
Miembro Desde 10/18/13
608 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 300
