Saltar al contenido principal
Violin Strings Replacement
  1. Violin Strings Replacement, Strings: paso 1, imagen 1 de 2 Violin Strings Replacement, Strings: paso 1, imagen 2 de 2
    • Turn the peg belonging to the string you are wanting to change to loosen the string.
    • Violins have four string. The strings from left to right go: G, D, A, & E.
  2. Violin Strings Replacement: paso 2, imagen 1 de 1
    • Pull the string out of the peg.
  3. Violin Strings Replacement: paso 3, imagen 1 de 2 Violin Strings Replacement: paso 3, imagen 2 de 2
    • Remove the opposite end of the string from the fine tuner holder.
  4. Violin Strings Replacement: paso 4, imagen 1 de 2 Violin Strings Replacement: paso 4, imagen 2 de 2
    • Place new string in peg hole.
  5. Violin Strings Replacement: paso 5, imagen 1 de 1
    • Turn the peg to tighten the string.
  6. Violin Strings Replacement: paso 6, imagen 1 de 2 Violin Strings Replacement: paso 6, imagen 2 de 2
    • Place nub in fine tuner holder.
  7. Violin Strings Replacement: paso 7, imagen 1 de 1
    • Make sure the string is sitting in the groove in the bridge.
  8. Violin Strings Replacement: paso 8, imagen 1 de 1
    • Gently tug on string to make sure it is secure.
Conclusión
5 personas más completaron esta guía.
Un comentario
Thanks for this very clear set of instructions with clear images. I am an amateur violinist and broke a string while tuning. Even I could use these instructions and it was as easy as the post says. Thanks for posting and to ifixit in general.
Svasangana jeevi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 15,099
