Saltar al contenido principal
Vintage Mini Vornado Fan Blade Replacement
Qué necesitas
  1. Vintage Mini Vornado Fan Blade Replacement, Fan Blade: paso 1, imagen 1 de 2 Vintage Mini Vornado Fan Blade Replacement, Fan Blade: paso 1, imagen 2 de 2
    • Prop the cap out of each hole with a pry tool to remove the blade cap.
    • To remove the blade cap, you will need to pop out three different areas of the cap from the fan. There are three small holes around the perimeter of the fan that the cap is secured into.
  2. Vintage Mini Vornado Fan Blade Replacement: paso 2, imagen 1 de 1
    • Face the front of the fan and pull the blade directly towards you to loosen it.
    • Pull the blade out of the rod.
    • Take note of the blade's orientation.
  3. Vintage Mini Vornado Fan Blade Replacement: paso 3, imagen 1 de 1
    • If you have purchased a new blade, make sure the orientation matches the one you just removed.
  4. Vintage Mini Vornado Fan Blade Replacement: paso 4, imagen 1 de 1
    • Use a cloth to dust the blade or other interior areas of the fan.
  5. Vintage Mini Vornado Fan Blade Replacement: paso 5, imagen 1 de 1
    • Place the blade back inside of the fan.
    • The blade should fit snug when the rod is fully inserted.
  6. Vintage Mini Vornado Fan Blade Replacement: paso 6, imagen 1 de 2 Vintage Mini Vornado Fan Blade Replacement: paso 6, imagen 2 de 2
    • Place the blade cap on and secure it into the three holes.
    • Use a pry tool with a cloth to help apply pressure and push the cap into place.
Linea de Meta
Una persona más ha completado esta guía.
Claire Minahan
Miembro Desde 02/01/23
169 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 2-3, Johann Winter 2023 Miembro de Cal Poly, Team 2-3, Johann Winter 2023
CPSU-JOHANN-W23S2G3
2 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 20
Todo El Tiempo: 312
