Saltar al contenido principal
Vicks FilterFree Plus Ultrasonic Mist Maker Replacement
Qué necesitas
  1. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Tank Cap: paso 1, imagen 1 de 1
    • Ensure the device is clear of water before disassembling.
    • Orient the device so the nozzle is facing the ceiling.
    • Twist off the primary water holding cap.
  2. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 2, imagen 1 de 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 2, imagen 2 de 2
    • Place the device upside down so that the tank cap is facing you.
    • Use your hands to twist the tank cap and remove it from the device.
  3. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Ultrasonic Mist Maker: paso 3, imagen 1 de 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement, Ultrasonic Mist Maker: paso 3, imagen 2 de 2
    • Remove the three screws from the base of the device using a T20 Torx screwdriver.
    • Remove the base of the humidifier to access the components.
  4. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 4, imagen 1 de 2 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 4, imagen 2 de 2
    • Gently remove the inner shield for the primary board to access the wiring for the humidifier.
  5. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 5, imagen 1 de 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 5, imagen 2 de 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 5, imagen 3 de 3
    • Remove the square heat shield by unscrewing the two screws using a Phillips #1 screwdriver.
    • Unclip the mist maker power cord.
  6. Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 6, imagen 1 de 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 6, imagen 2 de 3 Vicks FilterFree Plus Ultrasonic Mist Maker Replacement: paso 6, imagen 3 de 3
    • Remove the triangle shaped heat shield by unscrewing the three screws using a Phillips #1 screwdriver.
    • Take note of the mist maker's orientation for reassembly.
    • Remove the mist maker from the device.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 20
Todo El Tiempo: 398
