Saltar al contenido principal
Vertical Blind Repairing
Qué necesitas
Documento destacado
  1. Vertical Blind Repairing, View the problem: paso 1, imagen 1 de 1
    • 1. Identify the problem with the blind.
  2. Vertical Blind Repairing, Removal: paso 2, imagen 1 de 1
    • 2. Use your hand to carefully remove the blind.
  3. Vertical Blind Repairing, Examine: paso 3, imagen 1 de 1
    • 3. Look at the part you took off and see if the problem is with the top part of the blind.
  4. Vertical Blind Repairing, Material Ready: paso 4, imagen 1 de 1
    • 4. Make sure to have some glue or tape to fix the hole on top of the blind so you can be able to reassemble it.
  5. Vertical Blind Repairing, Patience: paso 5, imagen 1 de 1
    • 5. Wait a few minutes for the glue to dry.
  6. Vertical Blind Repairing, Repair: paso 6, imagen 1 de 1
    • 6. Reassemble the blind in the same place.
  7. Vertical Blind Repairing, Finish: paso 7, imagen 1 de 1
    • 7. Test the blinds by moving them side to side.
Conclusión
Documentos Adjuntos
Group 3
Miembro Desde 10/31/18
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 284
