Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
VersaMed iVent 201 Power Pack Replacement
Qué necesitas
    1. VersaMed iVent 201 Power Pack Replacement, Power Pack: paso 1, imagen 1 de 1
      • Remove the four 3mm x 20mm Phillips screws located on the corners of the power pack.
      Pregunta a FixBot
      Agregar Comentario
    2. VersaMed iVent 201 Power Pack Replacement: paso 2, imagen 1 de 1
      • Pull the power pack from the compartment using black handle.
      Pregunta a FixBot
      Agregar Comentario
    3. VersaMed iVent 201 Power Pack Replacement: paso 3, imagen 1 de 1
      • Remove the five 3mm x 10mm Phillips screws and washers from the back of the power pack. Lift off the cover after.
      Pregunta a FixBot
      Agregar Comentario
    4. VersaMed iVent 201 Power Pack Replacement: paso 4, imagen 1 de 1
      • Turn the battery pack upside down and take the battery out of the casing.
      • When reassembling, listen for the sound of the cooling fan for confirmation that the connection was successful.
      Pregunta a FixBot
      Agregar Comentario
    5. VersaMed iVent 201 Power Pack Replacement: paso 5, imagen 1 de 1
      • Remove the two spade connectors using pliers.
      • When assembling the power pack, MAKE SURE to connect the red wire to the positive terminal and the black wire to the negative terminal of the battery.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
To reassemble your device, follow these instructions in reverse order. Caution: MAKE SURE THE RED WIRE IS CONNECTED TO THE POSITIVE TERMINAL AND THE BLACK WIRE IS CONNECTED TO THE NEGATIVE.
Jeffrey Yin
Miembro Desde 04/09/20
265 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S7-G17, Paton Spring 2020 Miembro de Cal Poly, Team S7-G17, Paton Spring 2020
CPSU-PATON-S20S7G17
Miembros de 2
24 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 531
