Saltar al contenido principal
Verizon Wireless CDM 7075 Keypad Replacement
Qué necesitas
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: paso 1, imagen 1 de 2 Verizon Wireless CDM 7075 Keypad Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Verizon Wireless CDM 7075 Keypad Replacement: paso 2, imagen 1 de 1
    • Carefully remove the battery from the phone by prying the battery from the top.
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: paso 3, imagen 1 de 1
    • Pry off the top cover on the back of the phone.
  4. Verizon Wireless CDM 7075 Keypad Replacement: paso 4, imagen 1 de 1
    • You will then remove the screws from the back of the phone.
  5. Verizon Wireless CDM 7075 Keypad Replacement: paso 5, imagen 1 de 1
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
  6. Verizon Wireless CDM 7075 Keypad Replacement: paso 6, imagen 1 de 1
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
  7. Verizon Wireless CDM 7075 Keypad Replacement: paso 7, imagen 1 de 1
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
Conclusión
To reassemble your device follow these instructions in reverse order.
Una persona más ha completado esta guía.
Corey Ryman
Miembro Desde 10/14/11
255 Reputación
4 Guías creadas
Equipo
James Madison, Team 2-4, Allen Fall 2011 Miembro de James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 1,151
