Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
This easy-to-follow guide will teach you how to replace the battery for the Verizon Wireless CDM 7075 in 2 simple steps. No tools or background knowledge is necessary for this guide.
  1. Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off. Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Carefully remove the battery from the phone by prying the battery from the top.
    • Carefully remove the battery from the phone by prying the battery from the top.
Conclusión
2 personas más completaron esta guía.
Corey Ryman
Miembro Desde 14/10/11
255 Reputación
4 Guías creadas
Equipo
James Madison, Team 2-4, Allen Fall 2011 Miembro de James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 967
