Saltar al contenido principal
Verizon M1424WR Refresh Button Replacement
Qué necesitas
  1. Verizon M1424WR Refresh Button Replacement, Refresh Button: paso 1, imagen 1 de 1
    • Flip the device so that the bottom is facing up.
  2. Verizon M1424WR Refresh Button Replacement: paso 2, imagen 1 de 3 Verizon M1424WR Refresh Button Replacement: paso 2, imagen 2 de 3 Verizon M1424WR Refresh Button Replacement: paso 2, imagen 3 de 3
    • Insert the plastic-opening tool under the silver labeled casing.
    • Carefully pry at different intervals around the silver labeled casing to separate the silver casing from the top and bottom casing.
  3. Verizon M1424WR Refresh Button Replacement: paso 3, imagen 1 de 2 Verizon M1424WR Refresh Button Replacement: paso 3, imagen 2 de 2
    • Unscrew the five 10-mm screws on the bottom of the router using a Phillips #0 screwdriver.
  4. Verizon M1424WR Refresh Button Replacement: paso 4, imagen 1 de 2 Verizon M1424WR Refresh Button Replacement: paso 4, imagen 2 de 2
    • Use a plastic-opening tool and pry the top casing from the bottom casing to expose the circuit board in the bottom half of the device.
  5. Verizon M1424WR Refresh Button Replacement: paso 5, imagen 1 de 1
    • Locate the refresh button.
  6. Verizon M1424WR Refresh Button Replacement: paso 6, imagen 1 de 3 Verizon M1424WR Refresh Button Replacement: paso 6, imagen 2 de 3 Verizon M1424WR Refresh Button Replacement: paso 6, imagen 3 de 3
    • Apply pressure with your finger to the black tab that retains the refresh button while using your other hand to pull the bottom of the refresh button from the post.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 371
