Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement
Qué necesitas
    1. Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement, Battery: paso 1, imagen 1 de 2 Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement, Battery: paso 1, imagen 2 de 2
      • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
      Pregunta a FixBot
      Agregar Comentario
    2. Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement: paso 2, imagen 1 de 2 Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement: paso 2, imagen 2 de 2
      • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
      • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
      • The back should be completely removed.
      Pregunta a FixBot
      Agregar Comentario
    3. Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement: paso 3, imagen 1 de 1
      • The battery should now be visible. Gently grasp the edges to lift it out of the device.
      • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
      Pregunta a FixBot
      Agregar Comentario
    1. Verizon Jetpack 4G LTE Mobile Hotspot SIM Card Replacement, SIM Card: paso 4, imagen 1 de 1
      • Now that the battery is out, the SIM Card should be visible. Simply grasp it and pull it out of the device.
      • The device in picture no longer has a SIM card but a normal device will likely have a SIM card once opened.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Madison Asaro
Miembro Desde 10/08/18
243 Reputación
2 Guías creadas
Equipo
Marist, Team S1-G3, Chaterdon Fall 2018 Miembro de Marist, Team S1-G3, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G3
Miembros de 3
8 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 37
Todo El Tiempo: 4,122
