Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Verizon Ellipsis Jetpack MHS800L Screen Replacement
Qué necesitas
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: paso 1, imagen 1 de 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: paso 1, imagen 2 de 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: paso 1, imagen 3 de 3
      • Remove the SIM card, that is located on top of the Jetpack.
      Pregunta a FixBot
      Agregar Comentario
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 2, imagen 1 de 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 2, imagen 2 de 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 2, imagen 3 de 3
      Herramienta utilizada en este paso:
      Phillips #00 Screwdriver
      $5.49
      • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
      • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
      • You may need to peel back a piece of double sided tape covering the screw hole.
      Pregunta a FixBot
      Agregar Comentario
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 3, imagen 1 de 1
      • Remove three 1.25 mm screws.
      Pregunta a FixBot
      Agregar Comentario
    4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 4, imagen 1 de 1
      iFixit Opening Picks (Set of 6)
      $4.95
      Pregunta a FixBot
      Agregar Comentario
    5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 5, imagen 1 de 1
      • Once the cover is off, this is what your device will look like.
      Pregunta a FixBot
      Agregar Comentario
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: paso 6, imagen 1 de 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: paso 6, imagen 2 de 2
      • Once you have the case off of your device gently pull your battery away from the device.
      • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
      Pregunta a FixBot
      Agregar Comentario
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 7, imagen 1 de 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 7, imagen 2 de 2
      • With a pair of Tweezers remove the yellow tape covering the battery wires.
      Pregunta a FixBot
      Agregar Comentario
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 8, imagen 1 de 1
      • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
      • Do not squeeze the wires to hard you may damage them and cause a short.
      Pregunta a FixBot
      Agregar Comentario
    4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 9, imagen 1 de 1
      • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
      Pregunta a FixBot
      Agregar Comentario
    1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: paso 10, imagen 1 de 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: paso 10, imagen 2 de 3 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: paso 10, imagen 3 de 3
      • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
      Pregunta a FixBot
      Agregar Comentario
    2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 11, imagen 1 de 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 11, imagen 2 de 2
      • Using the Tweezers gently coax the display data cable out of circuit board connector.
      • Do not squeeze the display data cable to hard you may damage it and cause a short.
      Pregunta a FixBot
      Agregar Comentario
    3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 12, imagen 1 de 2 Verizon Ellipsis Jetpack MHS800L Screen Replacement: paso 12, imagen 2 de 2
      • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team 3-3, Baechle Spring 2016 Miembro de IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 29
Todo El Tiempo: 2,514
