Introducción
In every tablet, the screen is the most vulnerable component of the device and is prone to damage. If the screen on your tablet is cracked or if the images aren’t properly showing up on your screen, then the screen needs to be replaced.
Qué necesitas
Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
Remove the back case.
Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
Remove the speaker from the device.
Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
Una persona más ha completado esta guía.
