Saltar al contenido principal
Verizon Ellipsis 8 Screen Replacement
Qué necesitas
  1. Verizon Ellipsis 8 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Screen Replacement: paso 2, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Screen Replacement: paso 3, imagen 1 de 1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Screen Replacement: paso 4, imagen 1 de 1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Screen Replacement, Speaker: paso 5, imagen 1 de 3 Verizon Ellipsis 8 Screen Replacement, Speaker: paso 5, imagen 2 de 3 Verizon Ellipsis 8 Screen Replacement, Speaker: paso 5, imagen 3 de 3
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
  6. Verizon Ellipsis 8 Screen Replacement, Screen: paso 6, imagen 1 de 1
    • Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
Conclusión
Una persona más ha completado esta guía.
Sreedhar Kesari
Miembro Desde 11/11/19
190 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G2, Stella Fall 2019 Miembro de IUPUI, Team S2-G2, Stella Fall 2019
IUPUI-STELLA-F19S2G2
4 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 1,027
