Saltar al contenido principal
Verizon Ellipsis 8 Button Replacement
Qué necesitas
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: paso 1, imagen 1 de 1
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
  2. Verizon Ellipsis 8  Button Replacement: paso 2, imagen 1 de 1
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
  3. Verizon Ellipsis 8  Button Replacement: paso 3, imagen 1 de 1
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
Conclusión
Jack
Miembro Desde 02/06/19
589 Reputación
3 Guías creadas
Equipo
UC Davis, Team S18-G6, Lore Winter 2019 Miembro de UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 442
