Introducción
This guide will show you how to replace the front facing speakers on the Verizon Ellipsis 7. This is important to continue to use the Verizon Ellipsis 7 without using headphones. One of the hazards of this process is the potential to break or lose components of your device if not done properly.
Qué necesitas
Hold down the power button until the screen goes black to turn off the device.
Remove the SIM card from the device to prevent damage.
To remove the SIM card, open the SIM card cover on the side of the device.
Push SIM card in and pull it out after hearing a click.
Herramienta utilizada en este paso:Tweezers$4.99
Remove the charging (micro-USB) port.
Unscrew the indicated screws using the Phillips #00 screwdriver.
Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
Remove 2 screws from each speaker, 4 screws in total, using a Phillips #00 screwdriver.
2 personas más completaron esta guía.
