Saltar al contenido principal
Verizon Ellipsis 10 Headphone Jack Replacement
Qué necesitas
  1. Verizon Ellipsis 10 Headphone Jack Replacement, Back Cover: paso 1, imagen 1 de 1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Headphone Jack Replacement, Battery: paso 5, imagen 1 de 1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Headphone Jack Replacement: paso 6, imagen 1 de 1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Headphone Jack Replacement: paso 8, imagen 1 de 1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Headphone Jack Replacement: paso 9, imagen 1 de 1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Headphone Jack Replacement, Headphone Jack: paso 10, imagen 1 de 1
    • Locate headphone jack and volume buttons.
  11. Verizon Ellipsis 10 Headphone Jack Replacement: paso 11, imagen 1 de 1
    • Pull out the blue/white connector from the circuit board.
  12. Verizon Ellipsis 10 Headphone Jack Replacement: paso 12, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Gently disconnect the red/black wire from circuit board using a pair of tweezers.
  13. Verizon Ellipsis 10 Headphone Jack Replacement: paso 13, imagen 1 de 1
    • Remove all three M1.5 screws with a Phillips #00 screwdriver.
  14. Verizon Ellipsis 10 Headphone Jack Replacement: paso 14, imagen 1 de 1
    • Pull out the circuit board.
    • Be careful not to lose the button covers, as there is nothing holding them in the device.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 215
