Introducción
In this guide you will remove a total of three pieces to replace the keyboard. It will be a combination of prying and pulling to complete the task. During this process, it would be a good idea to have some electrical cleaner handy to clean the connections and the plastic pieces of all unwanted residue. This is an easy replacement and can be done within an hour. The only tools needed will be a spudger.
Qué necesitas
Place the notebook on the table, with the battery facing away from you.
Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
Maintain holding the right switch in the "unlock" position.
Use your left hand to slide the left switch from "lock" to "unlock".
Place the laptop fully opened with the keyboard facing upwards.
Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
