Saltar al contenido principal
Velocity NoteMagix M10 A82 Hard Drive Replacement
Qué necesitas
  1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Hard Drive Replacement: paso 2, imagen 1 de 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: paso 2, imagen 2 de 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  4. Velocity NoteMagix M10 A82 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Lift the HDD plate off of the back to reveal the hard drive.
  5. Velocity NoteMagix M10 A82 Hard Drive Replacement: paso 5, imagen 1 de 2 Velocity NoteMagix M10 A82 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
Conclusión
Sam Middleton
Miembro Desde 10/01/13
401 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-9, Forte Fall 2013 Miembro de Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 11
Todo El Tiempo: 308
