Introducción
This guide will show how to safely remove the RAM from the NoteMagix M10 A82 netbook.
Partes
No se requieren partes.
  1. Place the notebook on the table, with the battery facing away from you. Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Maintain both left and right switches in the "unlock" position. Use your forefingers to push the battery out of the computer.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place. Use the spudger to lift the DDR panel off.
    • Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place.
    • Use the spudger to lift the DDR panel off.
  5. Push in the tabs on the sides that contain the RAM. Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you. Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
    • Push in the tabs on the sides that contain the RAM.
    • Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
Conclusión
Sam Middleton
Miembro Desde 01/10/13
401 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 14-9, Forte Fall 2013 Miembro de Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Miembros
6 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 218
