Saltar al contenido principal
Velocity Micro Cruz Speaker Replacement
Qué necesitas
  1. Velocity Micro Cruz Speaker Replacement, Remove the Back: paso 1, imagen 1 de 1
    • Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
    • Gently work the tool around the diameter of the tablet until the back pops completely off.
  2. Velocity Micro Cruz Speaker Replacement, Remove All Screws: paso 2, imagen 1 de 2 Velocity Micro Cruz Speaker Replacement, Remove All Screws: paso 2, imagen 2 de 2
    • Use the screwdrivers to remove all the screws.
    • Ensure that all screws are removed before moving on to the next step.
  3. Velocity Micro Cruz Speaker Replacement, Remove LCD Connector: paso 3, imagen 1 de 1
    • Remove the bottom LCD connector by gently pulling it away from the motherboard.
  4. Velocity Micro Cruz Speaker Replacement, Separate the Frame from the Housing: paso 4, imagen 1 de 1
    • Identify the speaker wires.
    • Use a plastic opening tool to gently pry underneath the frame of the grey plastic frame until it completely separates from the housing.
  5. Velocity Micro Cruz Speaker Replacement, Remove and Replace the Speaker: paso 5, imagen 1 de 1
    • Use the wire cutters to clip the speaker wires in the middle
    • Use a plastic opening tool to remove the speaker.
    • Insert the new speaker in its place and solder the old and new wires together.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Conclusión
T Smith
Miembro Desde 11/02/16
205 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 113
